Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Oh man, that's not good! I think that you're probably out of luck. Here is a last resort though: Move the C2 file to a new folder, then go to your objects browser tray and select the option to "Open New Folder" and navigate to the folder you just put the C2 file in. You will probably get a blank or question mark icon in the object tray; however, drag that into a new C2 document. If this works, immediatley do a Save As and also drag the object back into the object browser which will create yet another back up of the object. Otherwise, well, there is no otherwise... :P Mark
Hi Mark, I tried your trick but didn't work poor me...Anyways I opened the C2 file in notepad and tried to delete some part of the coding in attempt to retrieve some part. Having removed some part of the code I retrieved right leg of the body. Unfortunately thats it i have been able to retrieve. But thats Ok I guess at least got sth to start with again... Does anyone know why this error comes though ?
Desperate, Since C2 files are text files, you can obviously modify anything you wish... if you fully understand the stuff. There is too much to explain, but essentially, various data structures in the file "point" to each other. Some structures are general classes, others are instances of those classes. If you find a pointer (name) in one of your instances, for instance (no pun), and find no corresponding class definition, then you have found a nil poiner... it points to nothing. This is so general as to be useless. Much study of the data structures is required to successfully modify the text files. Good luck, Jeff
Hi there, I managed to make a human body in Carrara 2.0 to give it IK, when I tried to oepn it next time it gave me this error "A nil pointer error occured while executing Open" I have no idea why this error is coming. i spend some valuable time doing that object and I don't wanna loose it unfortunately I haven't kept the backup of that coz I was still doing it. IF anyone can help me how to retrieve the file u'll save me ...... God bless u thanks heaps deserted
