Wed, Jan 8, 1:55 AM CST
Subject: Copyin' Full Body Morfs
FreeBass ( ) posted Sun, 21 September 2003 at 1:53 PM ยท edited Wed, 08 January 2025 at 1:47 AM
OK, so I DL'd Netherworks' V3/ V2 Hybrid (V3 head/ V2 Bod), unpacked/ assembled it, then began movin' V2's morf targets over. Everthin' went well w/ MorfManager, except it don' support FBMs. So I tried Cr2 Edit (V 1.52)...nuffin'! It seemed to work w/in Cr2Edit, but when I saved & tried to load the new figger, she din't appear. So I tries doin' it manually.....SHRIIIIIIEEEEK!!! Any help on this subject would be greatly 'ppreciated. TIA FreeBass
WARNING!
This user has been known to swear. A LOT!
SWAMP ( ) posted Sun, 21 September 2003 at 2:13 PM
In MM..load a prop first(any prop)..then load the cr2. Sounds crazy,but the FBM will now show...and can be transfered. SWAMP
pdxjims ( ) posted Sun, 21 September 2003 at 5:28 PM
I don't think you mean a prop, I think you mean a pose. At least, my version of MM doesn't load props. Is there a new version out? I've got MM4. I know Mr. x was working on a new version, but I haven't heard anything about it.
SWAMP ( ) posted Sun, 21 September 2003 at 6:17 PM
Sorry..I'm not all here today(flu)..yes it's a pose file(pz2)not a prop that you load first. Actually you can rename the cr2 to pz2,and do it that way...but it's easier to just load a POSE first. Thanks for the correct info,pdxjims. (sniffy)SWAMP
FreeBass ( ) posted Sun, 21 September 2003 at 6:22 PM
Tanx a whole bunch 8-) That kinda-sorta worked w/ a pz3... The dials appeared, but they don' work :'-( ???
WARNING!
SWAMP ( ) posted Sun, 21 September 2003 at 6:37 PM
..let me see if I can get this right between sniffing and hacking... You can't JUST transfer FBM..you also need to transfer the morphs to all the body parts for FBM to work. Like breast1 for LCollar transfered to LCollar,etc.etc....for breast1 FBM to work... SWAMP
Jaager ( ) posted Sun, 21 September 2003 at 6:59 PM
The dials in BODY are not morphs (valueParm) they are masters for the actual morphs. The actual morphs have ERC code - and for FBM - that code has BODY as the master "group" and the valueParm as the master channel. The ERC code then multiplies the master dial value by the rate (deltaAddDelta) and adds that to the dial value for the actual morph. (Which value the dial does not show.) A morph is the group it is for - an alternate shape for the group, but otherwise, it is exactly the group. No deviation other than point location is allowed.
FreeBass ( ) posted Sun, 21 September 2003 at 10:55 PM
OK...I got it...almost. I copied/renamed my base V2 to a pz2, & opened it & my base Hybrid in MM. I copied the body part Morfs only to the Hybrid (did morfs + channels B4, I tink) & ONLY the channels to the BODY.....it works! But now the thighs are separatin' from the buttocks...
WARNING!
