The dials in BODY are not morphs (valueParm) they are masters for the actual morphs. The actual morphs have ERC code - and for FBM - that code has BODY as the master "group" and the valueParm as the master channel. The ERC code then multiplies the master dial value by the rate (deltaAddDelta) and adds that to the dial value for the actual morph. (Which value the dial does not show.) A morph is the group it is for - an alternate shape for the group, but otherwise, it is exactly the group. No deviation other than point location is allowed.
OK...I got it...almost. I copied/renamed my base V2 to a pz2, & opened it & my base Hybrid in MM. I copied the body part Morfs only to the Hybrid (did morfs + channels B4, I tink) & ONLY the channels to the BODY.....it works! But now the thighs are separatin' from the buttocks...
WARNING!
This user has been known to swear. A LOT!
OK, so I DL'd Netherworks' V3/ V2 Hybrid (V3 head/ V2 Bod), unpacked/ assembled it, then began movin' V2's morf targets over. Everthin' went well w/ MorfManager, except it don' support FBMs. So I tried Cr2 Edit (V 1.52)...nuffin'! It seemed to work w/in Cr2Edit, but when I saved & tried to load the new figger, she din't appear. So I tries doin' it manually.....SHRIIIIIIEEEEK!!! Any help on this subject would be greatly 'ppreciated. TIA FreeBass
WARNING!
