Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Hi aljen, do this open Bryce , set it up howerver you like it,(make sure you clik on the interface button on the left below the rayspray tool also go into document setup and select "Max recommended" name it "Default.br4. hit Save That will launch automatically everytime you open Bryce. be sure you do not save over this file, always use the "Save as"command when your saving your work. Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
Attached Link: http://www.aljen.de
After every programm lauch (yes, I _do_ shut down Bryce from time to time ;) Bryce 4 shows a new standard window, which is rather tiny on a 19 inch display. I have to switch in up every time. Is there a way to tell Bryce to keep up the recent picture size? Of course, I have marked the option in Settings, but this doesn't seem to have an influence upon the startup document. MacOS 9.0.4 D, Bryce 4 German. T.I.A.!
