Thu, Jan 23, 6:26 PM CST
Subject: Just wondering?
Apache2k ( ) posted Fri, 26 September 2003 at 3:29 AM · edited Thu, 23 January 2025 at 3:34 PM
Is it normal that my P4 2.8 1 GB memory is extreme slow even when i have one character on screen. ( the second character is out of question) Do i have some seetings wrong? Any information please.? TIA, A2k
TrekkieGrrrl ( ) posted Fri, 26 September 2003 at 3:51 AM
What OS do you use? No it doesn't sound right. How large is your swap-file? Have you installed the memory updater for P4? Habe you defragged your drive recently? And what character are you using?
TrekkieGrrrl ( ) posted Fri, 26 September 2003 at 3:52 AM
doh, habe = have. No it WAS a typo and not an attempt to speak german LOL
Apache2k ( ) posted Fri, 26 September 2003 at 4:00 AM
Its win2002 Poser 5, havent updated anything. Everything else is works fine. Swap file is over 1,5 gb. I use the basic characters in poser. Thanks for quick reply.
randym77 ( ) posted Fri, 26 September 2003 at 5:17 AM
Something is definitely wrong. My computer is like yours, except I have XP, and it's quite fast with only one character loaded. Do you have all the Poser 5 updates installed? The service releases really aren't optional with Poser 5. They are nececessary for the program to run decently.
Apache2k ( ) posted Fri, 26 September 2003 at 5:20 AM
well i did re install it and now its a little bit faster.. ill also run the update... How can i calculate if its really slow, maybe its just me feeling that its slow? is there any kind of test? thanks.
randym77 ( ) posted Fri, 26 September 2003 at 5:27 AM
Attached Link: Poser CPU test
There was a Poser 5 "benchmark" sort of test, run right here in this forum. You download a standard scene, then time (with a watch) how long it takes to render. See the link. Try running the test, and comparing your time with what people who had similar computers got.
Apache2k ( ) posted Fri, 26 September 2003 at 6:01 PM
Thank you very much now its 3 times faster the result was over 600 sec to render before update , now its 195 sec. :)) thanks
randym77 ( ) posted Fri, 26 September 2003 at 10:40 PM
Wow, that's quite an improvement. What did you do to speed it up? Just reinstall Poser 5?
Apache2k ( ) posted Sat, 27 September 2003 at 8:22 AM
I did re install poser 5 and sr3, i had no update before that. and did also update my ati radeion drivers. Thanks.
