Wed, Feb 12, 3:29 AM CST
Subject: oh oh...think I broke Bryce
JC_01 ( ) posted Fri, 26 September 2003 at 1:45 PM · edited Sun, 09 February 2025 at 9:19 PM
things aren't looking good.... everytime I try to open an object in bryce today, it freezes on me...and crashes... what i think may be the culprit.... I wanted to organize all my objects i save in the user files, so I could seperate by categories... I copied the rocks .obj from the installed folser, and pated it into the user folder, opened bryce and deleted all the rocks from it... copied it 4 more times, renaming each as I went to things like Jen's furniture, Jen's outdoor stuff etc. Next I went back and renamed user to collected, and opened bryce again, and began moving things from that folder into the others by opening the object, and adding it into the new slots where i want them... after I added them to the new slots, I deleted them from the original spot. after about 5 or 6 things moved like this, I can't open any of thos eimages, not even the simple ones without bryce freezing and "not responding" hellppppp LOL Jen
JC_01 ( ) posted Fri, 26 September 2003 at 1:47 PM
pated = pasted
JC_01 ( ) posted Fri, 26 September 2003 at 1:54 PM
this is the last thing I actually made and rendered, and saved alone, before this happened...LOL thinking I better post now before it does completely...LOL Jen
brittmccary ( ) posted Fri, 26 September 2003 at 2:54 PM
I have NO idea what has happened to your Bryce... (is your HD running full?) But the cup is very well modelled! AND textured! Well done!
danamo ( ) posted Fri, 26 September 2003 at 3:01 PM
Nice cup Jen! I hope you get your Bryce up and running soon.
Rayraz ( ) posted Fri, 26 September 2003 at 4:00 PM
Are you getting only black icons in the object libraries too?
(_/)
JC_01 ( ) posted Fri, 26 September 2003 at 4:15 PM
I can select everything ok, but when I press the check mark to say ok, it freezes.... I'm gonna try a defrag this weekend and a virus scan....who knows whats wrong...LOL Jen
TheBryster ( ) posted Fri, 26 September 2003 at 5:39 PM
Sounds like the 'Curse of the China Cup'. Everyone who makes a cup along these lines ends up with a major collapse............it's a Brycian thing..........
ocddoug ( ) posted Fri, 26 September 2003 at 5:52 PM
It sounds like one of your object catagories is corrupted. This has happened to me a dozen times: one of the objects in a catagory gets corrupted (for whatever reason...I don't know why this happens) and then that entire catagory is rendered useless. Whenever you try to import a model into a Bryce scene, is Bryce freezing up? Or does Bryce freeze up when you open a scene file? If your problem is the models, then you'll have to delete that object catagory (not the models) and start another one. A good rule of thumb is not to add too many objects to your catagories, because eventually one will become corrupted. Hope that helps! Doug
bikermouse ( ) posted Fri, 26 September 2003 at 10:08 PM
ocddoug, Yeah I noticed that too. I finally figured out - new project new category. no more than 7 or 8 objects in each category. move the file you suspect of being corrupt from bryce's folder explorer to a temporary one to see if that helps before deleteing anything.
Rochr ( ) posted Sat, 27 September 2003 at 1:32 AM
Sounds like a problem ive had as well. It happened when i started to delete objects. Eventually the machine chewed for everything i did in Bryce. If you can, try to export the objects, delete the categories and create new ones. Hope you solve it!
Rudolf Herczog
Digital Artist
www.rochr.com
Rayraz ( ) posted Sat, 27 September 2003 at 3:47 AM
I was thinking of a corrupt file too, but the only time my library files got corrupt the icons where gone too, that's why I asked :) I think the others have said it all now. There's not much I can add to it except for advising to always make backups.
(_/)
catlin_mc ( ) posted Sat, 27 September 2003 at 5:17 AM
I've never seen this happen...................yet. So I think I'll just go export all the things I've saved to Bryce in another folder, just to be on the safe side. Catlin
mboncher ( ) posted Sat, 27 September 2003 at 8:53 AM
This happened to a scene I was working on. Unfortunately, I had to delete it, and then everything worked fine. Still haven't gone back to redo it.
amethyss ( ) posted Sat, 27 September 2003 at 8:03 PM
What I would do is copy your br5's to a cd,then save your important objects on a cd or in a folder.Then uninstall Bryce and reinstall.Might help.
Painting: The art of protecting flat surfaces from the weather and exposing them to the critic_____website
JC_01 ( ) posted Sun, 28 September 2003 at 11:02 PM
ok, I exported all the stuff I made, put them in a folder, deleted all the stuff in bryce except one blank obp and duplicated it making many categories...lol After about 8 hours I almost have everything re-imported, my stuff and all the stuff I've collected along the way...lol What takes so long is all those files I got that open with no textures, and I have to smooth and texture them before saving them....takes forever...lol Anyhow, I finally got rid of that bug and can now go into that section without freezing... Thanks to everyone for all the hints, ideas, and help! Jen
