Fri, Feb 7, 10:22 AM CST
Subject: Challenge WIP3 Okinawa Airwar May 1945
GROINGRINDER ( ) posted Sun, 28 September 2003 at 1:47 AM Ā· edited Fri, 07 February 2025 at 10:20 AM
Still trying to get the smoke and explosions. I would appreciate if someone would post good volume smoke settings for my foreground smoke column.
chohole ( ) posted Sun, 28 September 2003 at 2:17 AM
This was the very simple one I used for the background smoke im my image "the clearance". Used it on rocks
The greatest part of wisdom is learning to developĀ  the ineffable genius of extracting the "neither here nor there" out of any situation...."
madmax_br5 ( ) posted Sun, 28 September 2003 at 2:19 AM
I like tweaking the "pollution" preset in the volume tab. The black smoke one with the fuzziness increased also works well.
GROINGRINDER ( ) posted Sun, 28 September 2003 at 3:15 AM
Thanks chohole and madmax br5!
vasquez ( ) posted Sun, 28 September 2003 at 4:56 AM
Are you using metaballs for the smoke? If so remember that metaballs don't work well with volumetric materials.
GROINGRINDER ( ) posted Sun, 28 September 2003 at 5:30 AM
Yes, vasquez I am. Thank you for that tidbit of info. I was unaware of that.
Flak ( ) posted Sun, 28 September 2003 at 6:00 AM
This is the smoke from my siege image. Used it in cylinders (with various darker and lighter versions of the same material).
Digital WasteLanD
GROINGRINDER ( ) posted Sun, 28 September 2003 at 6:36 AM
Thank you Flak.
JC_01 ( ) posted Sun, 28 September 2003 at 5:00 PM
GG, here's one you could try....it's just en alongated sphere, with the blue smog slab clouds in the wolume section, at these settings... Looking good otherwise tho...*grins*
elongated^ lol dern pc
GROINGRINDER ( ) posted Sun, 28 September 2003 at 11:01 PM
Thank you JC 01.
electroglyph ( ) posted Mon, 29 September 2003 at 5:04 PM
I just use regular spheres and let them run into each other. Metaballs do weird with textures.
GROINGRINDER ( ) posted Mon, 29 September 2003 at 8:09 PM
Thanks electroglyph.
