Tue, Jan 28, 4:26 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Why can't I export the standart shirt to MAX 2.5 ???
Holli ( ) posted Mon, 31 July 2000 at 3:57 AM ยท edited Mon, 27 January 2025 at 4:52 AM
Hello, look at the picture. Why does the shirt look so strange in MAX ? Everything else seems to be fine. I'm using the HABWARE plugins.
edriver ( ) posted Mon, 31 July 2000 at 7:40 AM
You'll get much better results exporting as a DXF and then importing it into MAX where you can save it as a MAX file.
Jim Burton ( ) posted Mon, 31 July 2000 at 9:47 AM
In Max, pick the shirt object, apply Smooth (not Mesh Smooth), then turn on autosmooth on down at the bottom of the pallette. Smooth groups seem to be on turned on in some Poser items, not in others, but check your OBJ2MAX settings, that should be on in any case in the plugin.
