I understand what you mean: Vue does have a "painterly" feel to it. I've used Bryce and have just bought Carrara both of which can produce quite stark, photo-like images.
One of Vue's strengths is the ability to create realistic haze, fog, clouds and muted sunlight just like in the real world.
Most Vue users produce landscapes which, due their very nature, are comprised predominantly of greens, greys and browns. OK so it's an over simplification of the glorious creation around us, but you get the idea:-)
Please also remember that all images posted to the gallery are crunched down from their original large file size. Something is always lost in that conversion process, usually the vegetation detail, which contributes to "flattening" the image.
However, Vue most definitely is more than capable of producing bright colours.
As to your dare, the last two works I've posted were partly experiments with vivid colouring in Vue. (I like things bright!) There are plenty of other examples in the Vue galleries. If you say what kind of image you want to see, I'm sure someone here will rise to the "mini-challenge" and post something from Vue matching your spec.
Finally, have you checked your monitor? It wasn't until I bought a good LCD screen that I realised what my old Sony CRT hadn't been showing me!
Cheers,
Mark
YL: I will keep a close eye on the challenge ! BigGreenFurryThing: First of all I love your latest Techie Trekkie ... very cool ! Concerning the monitor, I look at the images on three different monitors (an old one which doesn't have the brightest colours indeed), a brand new LCD monitor and at work at a 19" monitor) so I can compare it and I can see it at all monitors :) You are right about the fact that it is most of the time with large vegetation images that I get that 'dull' feeling. I don't say that the images are bad. Some are really outstanding, but they all look a bit similar. I get the feeling that all those are rendered with the default lighting settings. But it's all in my humble opinion. I know there are plenty of good examples of what Vue can do :) I just wanted to point it out because I get the feeling some people just don't know how to brighten up an image by using more spotlight at certain areas. I brought it up because I know Vue has a lot of potential and as soon as I have some money left I will buy it straight away. Until then I have to do it with your cool renders and just thought I might give you Vue users something to think about. In my opinion Renderosity shouldn't be only to display your work but to learn also. I know I've learned a lot from critical users in the Bryce, Terragen and MojoWorld forums ! Thanks for sharing your thoughts and insights !! Anne BTW: the August 2003 winning image is also one of those good examples of great colours in Vue ofcourse !
It's not the lighting that makes the image look dull. I'm not sure what "dull" stands for here, I think you mean sort of graininess in an image?
This is mainly caused by the simple fact that Vue can handle "only" 25 sub-rays. You can see it in extremely soft shadows and when using strong depth of field.
For comparison, Bryce 5 can smack images with 256 rays per pixel -meaning eternity-slow rendering but good quality of an image if other parts of Bryce-image are set OK.
I have no idea if Vue Pro handles more sub-rays -I was going to ask it when starting this post- so I can't tell whether images rendered with VuePro differ from Vue4-stills
I'm pretty new to Vueing around, but when I was asked to make an animation of tornado hitting a house, I had to choose between Lightwave and Vue. I chose making that 3second tv-spot with Vue because of the number of sub-rays -the grains gave the effect of dirt to be blown around. In action that meant lots of faster rendering with somewhat neat result.
Again, I'm new to Vueing and therefore don't know how "seniors" post-produce their still images with, but I've found that when making stills with strong DoF or soft lighting, programs like Neat Image Pro and Photoshop are my best friends: NIpro kicks grain out of the image and color correction and enhancement can be done in Photoshop.
Images in Renderosity's galleries, I think, are mostly made with only rendering image in Vue -if you post image through dozen different programs, the result is hardly an image only fitting to Vue d'Esprit gallery.
Hope this answered your question -even touched the topic:)
.mjt
Ok Dull was not the right description (but caught your attention). I think hazy and grainy are better words indeed. I think you all are clarifying a lot for me and I think that when I buy Vue I will definitely pay attention to your comments !! Hopefully others will profit from your comments as well ! Anne
By "hazy and grainy", you may mean the atmospherics and ambient light a lot of folks use. Vue does a lot of nifty stuff with atmospherics, and by using the haze and fog, along with ambient lights, I tend to get a hazier feeling to my images. It depends on what effect I want in my image. At least half the time, I lean away from ambient lighting towards more direct lighting, usually add several more lights as well as sunlight. But then, art and opinions are subjective, aren't they? I'm looking out my window right now, and the sky is a bit dull and overcast, and the colors in the landscape are a bit muted. "Hazy and grainy." Suggest you go back through the gallery, you will see plenty of vivid coloring in Vue renders.
Hazy and grainy can be avoided. Just possible to remove any fog and haze, and render to the best quality (user setting at minimum since Vue3). Light setting is also important...See for instance the september challenge pic above, does is look dull to you ? The colors are bright, seems to have not ambient, all the objects are very clear and net (seems no fog and haze). There are some other examples of that in the gallery (why not surfing through it?) ;=)
To me, it's the opposite. Vue is the one with the crisper renders, which is actually why I switched from Bryce. I always found Bryce to be not so crisp with no way to shut that off, no matter how I played with the settings. In Vue, you can shut off the atmospheric effects so that the image is chrystal clear with vibrant colors, such as agiel's image above, or you can have a very painterly degree of atmospheric effects to fit the mood. The choice is up to the artist, which is what I like about Vue.
I find that a lot of ambient light will give your picture a grainy look. The default Vue lighting has a lot of ambient since many new Vue users use the default lighting their images tend to look grainy. I found when reading posts and tutorials that many of the more seasoned Vue artists tend to steer away from a lot of ambient light. When I lowered or eliminated ambient light in my scenes my images looked sharper and less grainy.
Dave
I must add that haze and fogs are very difficult to adjust. I mean you want haze and fog in the background, you will have even a little amount of this in the foreground. Which will makes your pictures a little bit uniform in look. Very difficult to adjust. As it has been said above, try to highly decrease ambient light, which makes picture appear flat and dull. You will have to replace them by additional lights. That's why, a new Vue picture should always been done with a real "scratch" atmosphere. An atmosphere with zero ambient, zero fog, zero haze, white sky,...Creat it then save it and always begin a new scene with it, you can adjust the new atmosphere after... Beware there are other settings I don't know in Vue4 which are related with atmospheres and could disturb your "zero" atm. Yves
Both are great pictures, the last has modified the default Vue textures (probably) and has yellow light which makes look the pic more hot. Every 3D soft allow to modify the textures/colors to obtain what you want. Vue is a 3D renderer, it also allow to modify the tex as you want : want red plants? possible... want blue ones ? possible... Now I understand you want green one: that's possible...But sometimes changing default Vue tex... ;=) Yves
First of all, I don't have Vue d'Esprit myself (yet!), but I always look at the images posted here at renderosity and one thing is bugging me for quite some time now. Why are in general the colours in the Vue d'Esprit images so dull ? Aren't there possibilities to change or add more lighting spots ? This is important in my opinion because lightning can make or break an image. I mention this because I see such great compositions and then the dullness kills it for me ! I am just very curious and would like to see all of you Vue artists prove me wrong about the colours, I dare you :) Greetings from a wannabee Vue user, Anne
