Aldaron, That's what I was thinking. JC, If you made the house out of solid cubes there is no way a boolean will work from the inside ... unless... if that's what you did, duplicate the house, make the xyz's of the dup a little smaller and group the outside(+) bool to the inside(-) bool. Then you'll have to seperate out the window and boolean a hole(-) the size of the window to the house group(+). then insert the window into the hole and optionally group both(+). - TJ
Hi Jen, Seems I had the same problem working on the bates house.....did you try putting a light inside? Try viewing the camera from top, and side views.....sometimes things look different than they really are. Also might want to try viewing the house in solo mode, perhaps some of the trees are making things inside too dark. Btw, didn't get a chance to tell you before, you did an awesome job on that house and the landscaping around it :) Let me know if you figure out the problem.....still not sure what I did to fix mine lol. Teri R
yea, in the middle of working on it someplace, I took out the interior - booleans... so it's a cube with windows...lol When I tried working with the house, there were sooo many objects in that cluster, I decided to use a few less...LOL One thing I do know.... I'm not about to regroup 13 windows again...LOL I'll just have to rebuild the house hahahahah actually, I want to make it like a model house...with an inside and an outside....would love to start making furniture and stuff for it....grins the house model itself, while there's lines everywhere, isn't that big, but the whole scene file got to be pretty big...lol thanks for the help everyone, and thanks Teri, it's kinda like a picture of my dream house...lol Your house came out around the same time, and it looks fabulous..grins Jen
Ahhhh, yes, of course Jen. Bryce boolean are not real booleans and doesn't work like booleans in other modelers. As for grouping the 13 windows, you can select them all once and put them into the same select family giving them their own color. That way, whenever you need to select all the windows at once later to group them, you only need select the family color to select them all in one click.
ok, Playing around with my house, I wanted to see if it was piossible to decorate inside....but when I put the camera inside, I could not see out through the booleaned windows.... is this normal? and to I have to make multisectional walls to fix it? Thanks Jen
