Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
Yeah, I know. I'm only after the woven fabric. It should be for an ancient clothing. So it should only have a flat base color, but show the woven fabric. I have tried to put some tiled texture over an UV map, but I'm not succeeding by the UV seems. I'm not so good in UV mapper either.
Would be nice to know if it was possible to make from the procedural.
Another Q, is someone more comfortable with the new UV mapper inside C3 than UV mapper Pro? I found myself a little slow to understand it to be better than UV mapper Pro, which i'm used too.
Attached Link: http://www.eovia.com/carrara/user_proj_car_litst.jsp
Check out litst's night goggles model, which you can download from Eovia. He uses the brick pattern, repeated small, for the bump on the strip of fabric and it is very effective. Litst is a master at shaders and it's worth looking at how he does it. Hope this helps.Attached Link: http://www.shaders3d.com
If you also are looking for more shaders for CARRARA 3 you can find them at www.shaders3d.com.... one of the largest sources of shaders for carrara on the net.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi,
Trying to learn the shader in C3. Does anyone know how close you can come to make a textile bump for clothes. I wondered if you can manage to make a bump like that with the procedural.
I'm asking for help so I don't have to tweak a hundred years without a result.
At least tell me someone where I should start to tweak.
Thanks,
Snekkis
