Sat, Jan 11, 10:14 PM CST
Subject: Creating RSRs for my MAT files?
IronWhim ( ) posted Tue, 07 October 2003 at 6:21 PM · edited Sat, 11 January 2025 at 10:10 PM
I just finished a nifty tutorial on building a MAT file for some clothing I'm texturing. Very handy. Except that I can't find the RSRCONV.EXE anywhere, including the site of the guy who makes it. I click his link and it says file not found or something to that effect. Is there another solution? Thanks, Brian
Irish ( ) posted Tue, 07 October 2003 at 6:38 PM
Go to Free Stuff and do a search for Harper or RSR Converter and it will come up and it downloads fine. :) Irene
IronWhim ( ) posted Tue, 07 October 2003 at 8:36 PM
Thanks, Irene. If I'm not careful, I'm gonna start posting stuff to the Free section soon. :::does happy dance:::
Lyrra ( ) posted Tue, 07 October 2003 at 8:44 PM
I use the 'idiot' solution. Render your thing. Save picture. Make a new scene. Load a square prop. Apply the render as a material. Save as a prop. Use FileManager and steal the rsr for your actual MAT file. Delete the pp2. There ..low tech but it works
IronWhim ( ) posted Tue, 07 October 2003 at 10:24 PM
Actually, I'm quite fond of low tech. So basically I could do a render of, say, Koshini in hideously tacky leopard print hip huggers and simply steal the .rsr file from the figures to the pose file of the same name? Nefarious. I likes it.
ph0enixx ( ) posted Tue, 07 October 2003 at 11:12 PM
I second Lyrra, I use that low tech technique as well. Find it saves me time. :)
“Our real discoveries come from chaos, from going to the place that looks wrong and stupid and foolish.” – Palahniuk
Bobbie_Boucher ( ) posted Wed, 08 October 2003 at 6:37 AM
Attached Link: http://lcrepiliere.free.fr/
Get P3DO Explorer, by Yarp. You get the rsr converter, and many other essential utilities.
maclean ( ) posted Wed, 08 October 2003 at 3:39 PM
Lyrra, You can save a bit of time and trouble on your method. Do this. 1. Render using any square doc window. 2. Save image, then import it as a background (alt-f-i-b). 3. Go to any camera folder and save. 4. Steal the .rsr and kill the .cm2. No need for poser squares or new docs. I do huge batches of 'em like this, all one after the other. You can either do all the renders first, or do them one at a time and just clear the bkg image each time. mac - the lowest of the low-tech PS Here's the kb shortcut I discovered for new doc + no save. ctrl-n = new doc; TAB = don't save; spacebar = OK. Why spacebar works, I have no idea, but then, poser IS weird. If you press ENTER instead of spacebar, Poser tries to save. Go figure.
Bobbie_Boucher ( ) posted Thu, 09 October 2003 at 6:22 AM
I've never had any luck with rendering and using squares for backgrounds! Why not do it the easy way. If you have Poser Pro Pack or Poser 5: 1.) Change your document window size to 91x91, and render the image. 2.) Save as PNG. You can even do this for your library png/rsr images. 3.) Use P3DO Explorer to convert PNG to RSR. You're done.
RHaseltine ( ) posted Thu, 09 October 2003 at 6:28 AM
Maclean: ctrl-n, d is even quicker for new doc with no save.
maclean ( ) posted Thu, 09 October 2003 at 2:40 PM
Whoa!!!! That's brilliant! I just tried it now. How did you find that? It's not on the Poser leaflet with the kb shortcuts, is it? I don't remember ever seeing it. I'm a happy bunny now. Thanks! mac
RHaseltine ( ) posted Fri, 10 October 2003 at 2:28 PM
I just hoped it would be like a Windows dialogue box; when there isn't a text field, you just hit the shortcut key, and D was likeliest. I was slightly surprised when it worked, but considering how often I have to start over from scratch it was worth trying!
maclean ( ) posted Fri, 10 October 2003 at 4:35 PM
Ah well, another confirmation of an old-established fact.... ALL TOGETHER NOW - "Poser is WEIRD!!!" mac
