Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 9:50 pm)
Attached Link: http://lcrepiliere.free.fr/
Get P3DO Explorer, by Yarp. You get the rsr converter, and many other essential utilities.Lyrra, You can save a bit of time and trouble on your method. Do this. 1. Render using any square doc window. 2. Save image, then import it as a background (alt-f-i-b). 3. Go to any camera folder and save. 4. Steal the .rsr and kill the .cm2. No need for poser squares or new docs. I do huge batches of 'em like this, all one after the other. You can either do all the renders first, or do them one at a time and just clear the bkg image each time. mac - the lowest of the low-tech PS Here's the kb shortcut I discovered for new doc + no save. ctrl-n = new doc; TAB = don't save; spacebar = OK. Why spacebar works, I have no idea, but then, poser IS weird. If you press ENTER instead of spacebar, Poser tries to save. Go figure.
I've never had any luck with rendering and using squares for backgrounds! Why not do it the easy way. If you have Poser Pro Pack or Poser 5: 1.) Change your document window size to 91x91, and render the image. 2.) Save as PNG. You can even do this for your library png/rsr images. 3.) Use P3DO Explorer to convert PNG to RSR. You're done.
I just finished a nifty tutorial on building a MAT file for some clothing I'm texturing. Very handy. Except that I can't find the RSRCONV.EXE anywhere, including the site of the guy who makes it. I click his link and it says file not found or something to that effect. Is there another solution? Thanks, Brian
