Tue, Nov 12, 9:12 PM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Vue D'Esprit crashes.
blehman ( ) posted Thu, 09 October 2003 at 11:24 AM ยท edited Sun, 10 November 2024 at 4:20 AM
After I load a few trees or other objects into Vue I get error messages and it shuts down completely. There seems to be a problem between Vue D'Sprit and IE 6 on my system. Does any one have a suggestion how to correct this problem?
blehman
SAMS3D ( ) posted Thu, 09 October 2003 at 12:06 PM
Have you updated to 4.2? Sharen
blehman ( ) posted Thu, 09 October 2003 at 12:33 PM
No. I'm using 4.0 Will this stop the crashes? (updating to 4.2) blehman
Djeser ( ) posted Thu, 09 October 2003 at 12:37 PM
You should update at least to 4.12, and if you are still having problems, go to file/options, and turn of Open GL. That seems to cause problems for some folks.
Sgiathalaich
blehman ( ) posted Thu, 09 October 2003 at 12:59 PM
Thank you. below is the error message I'm getting each time. VUE4.EXE has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created. I did update to 4.12 and still receive the message. I'll try turning of Open GL. and let you know the results. blehman
Gaussian ( ) posted Thu, 09 October 2003 at 4:33 PM
I wonder why you come to the conclusion that bthe problem is IE 6 related?? My guess is that turning off OpenGL will solve your problems. If not; update your video driver. What kind of graphics card are you using?
enax ( ) posted Thu, 09 October 2003 at 11:42 PM
I didn't have this problem with VUE 4.12, XP Pro and IE6. Now I have this problem with VuePro, the program just disappears :(
