Mon, Dec 2, 9:02 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: when I export object from vue pro it has a message on the left bottom
estherau ( ) posted Sat, 11 October 2003 at 12:55 AM · edited Sun, 01 December 2024 at 5:04 AM
which says exporting 'whatever file format I chose' - the message seems to stay there after it's already exported. How long do I wait to see if it's finished? does it take a really long time? I have a mac but I just tried it on my husbands PC and the same thing happened. the message just seems to stay there in the bottom left hand corner even after it seems to already have exported. I feel I'm not making myself very clear but I'm hoping someone will understand this rambling question. Love esther
MY ONLINE COMIC IS NOW LIVE
kuroyume0161 ( ) posted Sat, 11 October 2003 at 1:43 AM
Do you get a progress bar as it's exporting or just the text and nothing to the right of it (the progress bar is missing)? Seems odd that this occurs on two different systems.
 -- Bjarne Stroustrup
estherau ( ) posted Sat, 11 October 2003 at 2:01 AM
Sorry I should have mentioned. On the PC at least I saw a progress bar but it only took seconds to complete and the next message says "exportingOBJ.obj..."
kuroyume0161 ( ) posted Sat, 11 October 2003 at 2:28 AM
That's odd. Well, you can be assured (I hope) that once the progress bar completes, the export is finished. Have you tried it with an object with a high polygon count to see if the progress bar is doing its thing properly? Once you move your mouse over a function or scene object, the status bar should be updated with information relevant to that and not stay on "exportingOBJ.obj...". Let me know if it goes away under that circumstance.
estherau ( ) posted Sat, 11 October 2003 at 2:41 AM
Yes, when I click on something, the message goes away but I was worrying that by doing that I was interrupting my export. Love esther
estherau ( ) posted Sat, 11 October 2003 at 2:44 AM
oh and I just tried putting it in poser and the texture is all stripy like an incomplete render. I think it wasn't actually finished yet. Love esther
kuroyume0161 ( ) posted Sat, 11 October 2003 at 1:02 PM
Have you looked inside the OBJ file itself (it's only a text file with a different extension)? Also, would be great to see a screen capture of the Vue Pro screen during export. I'm not having any problems with exportation. Has Vue Pro installed the update yet?
estherau ( ) posted Sat, 11 October 2003 at 6:45 PM
Hi, well I only just got vue pro. You mean there's an update already? Goodness! Okay, I didn't open the object as a texture file, but I did import it into poser and it looked shocking. Nothing like in vue. Love esther
estherau ( ) posted Sat, 11 October 2003 at 6:46 PM
sorry I meant text file. Ooops.
kuroyume0161 ( ) posted Sat, 11 October 2003 at 7:13 PM
They released a "beta update" during last week. If you tell Vue Pro to update (File->Check For Update), it will do so (unless it's only for the Windows version). I know what you mean. I've only just received Pro Friday before last. My suggestion is to update Vue Pro and export a simple object (e.g.: sphere, cube) and see how it imports into Poser and back into Vue Pro as well. Try several formats. If none of this seems to create useful results, you may want to contact E-on tech support for a resolution. Before that, though, the only other suggestion would be a reinstall. I found that the install doesn't "finish" and leaves some files uncopied. My exports appear to be working correctly, so this isn't a general issue.
estherau ( ) posted Sat, 11 October 2003 at 7:37 PM
Okay thanks. Well i did say yes update, but how do I know if it has done it or not? Love esther
kuroyume0161 ( ) posted Sat, 11 October 2003 at 9:02 PM
Version should be 4.50-02 Build 266001 if it updated.
estherau ( ) posted Sun, 12 October 2003 at 2:54 AM
Mine is 4.50-02 Build 265692
kuroyume0161 ( ) posted Sun, 12 October 2003 at 10:02 AM
That's tough to tell. There could be differences between Mac and Windows Build numbers. Have you tried export/import of a simple object and with what results?
estherau ( ) posted Sun, 12 October 2003 at 7:07 PM
yes, and the simple object looked okay, but didn't have any transparency info when I imported the object into poser. But the thing is I had to click on the vue screen because it still had that exporting message on the bottom left side, and that made the message go. But how do I know it was completely finished or I just didn't interrupt it? Why does that message stay after it's probably already exported? Also my exported more complex objects look dreadfull in poser and nothing like how they looked in vue. Love esther
kuroyume0161 ( ) posted Sun, 12 October 2003 at 8:18 PM
If you're using OBJ format, it won't have any texturing info, only groups. 3DS should include texturing info, but not certain about transparency.
