Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 4:58 am)
Attached Link: http://www.juno.dti.ne.jp/~yamato-k/VPstep1.html
Well I went to the attached link and tried to follow the directions. When I tried to follow the directions, I could not check the proper boxes as shown. (At least a checkmark would not appear). What gives? I can only check the third and fifth box. Anyone know what I'm doing wrong?Well. I have no clue what I just did, but I now have Tenten on Judy :) now for that new and improved body... could someone please explain what all those steps actually did???
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
you're doing one of the steps wrong ??? There are a couple of areas where you need to do stuff that are not in quite correct order..off to the side and stuff...so if you forget one of the side steps, maybe it doesn't work... not sure what else it could be.
Humankind has not
together.
1854
I'm still using the last Poser 5 SR-2 patch. I can't figure what could be wrong. You should be able to check any of the boxes at any time when exporting an object. The only thing that could cause a problem like this is your FFObj.arp & FFObj.rsr files are corrupt or missing. They should be in your Plugins folder.
