That is the strangest thing I ever saw! If I bring it up before I export, it doesn't work. but if I wait until the export window with the boxes comes up and then bring up the clock it works. THANK YOU - THANK YOU!!!!!!!!!!! I tried many things the past two days, but I would have never thought of that! Who comes up with these ideas anyway? THANKS AGAIN!!!!!!!!!!!!!
Yes, it is wierd. There's nothing magical about the clock, AFAIK, you just need to switch to another application and give it the focus before returning to Poser. Even using the clock, I've seen instances where you had to switch a couple of times to get it to work. I just tried to test this but for some reason the checkboxes now all work!?? I don't use export often but the bug usually occurs alost every time. I'm surprised it's still in P5 - shows how much P4 code is apparently still in there.
