Mon, Feb 3, 2:23 PM CST
Subject: Wavefront Export Problem - Please help
rwilliams ( ) posted Tue, 14 October 2003 at 6:29 PM ยท edited Fri, 24 January 2025 at 6:30 PM
When I want to export a wavefront file I cannot click in any boxes but the third and fifth box. I have reinstalled Poser5 and installed SR-3 plus the SR-3 figure update, but still no go. I also tried the same type of export in Poser4 and I can only click the same two boxes there. What am I doing wrong?
rwilliams ( ) posted Tue, 14 October 2003 at 6:30 PM
I want to click in the two boxes that are checked above to install Tenten Judy. Sorry, forgot to say that above.
nickedshield ( ) posted Tue, 14 October 2003 at 7:54 PM
When you get ready to export, bring up your system clock. Most people have it running on the task bar. Leave the clok open and you should be able to use all the checkboxes. Why this works- I don't know. Info came from an old thread.
rwilliams ( ) posted Tue, 14 October 2003 at 8:06 PM
That is the strangest thing I ever saw! If I bring it up before I export, it doesn't work. but if I wait until the export window with the boxes comes up and then bring up the clock it works. THANK YOU - THANK YOU!!!!!!!!!!! I tried many things the past two days, but I would have never thought of that! Who comes up with these ideas anyway? THANKS AGAIN!!!!!!!!!!!!!
sirkrite ( ) posted Tue, 14 October 2003 at 8:14 PM
Now that's a strange one! :D LOL!
Dave-So ( ) posted Tue, 14 October 2003 at 10:06 PM
can't hardly believe that one :) happy you got that thing working.. now for P5 Judy body fix....
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
OneShot ( ) posted Tue, 14 October 2003 at 11:13 PM
Check 1, 3, 4, 5
geoegress ( ) posted Tue, 14 October 2003 at 11:32 PM
well this is like totally odd :) learn something new everyday
lmckenzie ( ) posted Wed, 15 October 2003 at 3:46 AM
Yes, it is wierd. There's nothing magical about the clock, AFAIK, you just need to switch to another application and give it the focus before returning to Poser. Even using the clock, I've seen instances where you had to switch a couple of times to get it to work. I just tried to test this but for some reason the checkboxes now all work!?? I don't use export often but the bug usually occurs alost every time. I'm surprised it's still in P5 - shows how much P4 code is apparently still in there.
