Sat, Feb 15, 4:46 PM CST
Subject: Can i extract morph target from figure (& save it as OBJ) ?
Todo ( ) posted Thu, 03 August 2000 at 10:53 AM ยท edited Thu, 13 February 2025 at 2:05 PM
I Can export separate body parts from Poser.... but i want extract exactly morph target ... :) can i do this ?
arcady ( ) posted Thu, 03 August 2000 at 11:25 AM
Truth has no value without backing by unfounded belief.
Renderosity Gallery
rbtwhiz ( ) posted Thu, 03 August 2000 at 11:27 AM
Yes. Set all channels (dials) to zero(0), then set the desired morph to one (1) and export the bodypart with the morph applied... If your using 4.02 or higher you can forego the setting of dials to "0" because the obj export options allow you to export without world tranformations.. -Rob
rbtwhiz ( ) posted Thu, 03 August 2000 at 11:30 AM
...or you can use Mason's utility (Morph Manager) as arcady pointed out. -Rob
Mason ( ) posted Thu, 03 August 2000 at 11:37 AM
Grab Morph manager from http://www.geocities.com/mr1_x_1/index.html You also need the original obj. Just drag and drop the cr2 on either window then drag and drop the associated obj on the same window. Now right click on the MT and select export. Exports with no world transform and no material info.
Todo ( ) posted Fri, 04 August 2000 at 6:31 AM
Thanks everybody who answered ... :) Now i know more about Poser ... :)
