good start. Tree shadows need the be more pronounced. I know i am probably sounding like the broken record, but the zenith light system (http://www.renderring.com/zenith.zip) is ideal for this type of daylight scene. For the "too bryce-ish" sign you have, i suggest making ita terrainwith a very light displacement, or else make the bump map and specularity stronger on the square. For the tree back there, more leaves, smaller leaves, more branches/segment and no ambience.
I think he may have meant the tree was too Brycish. If so, maybe try to combine two or tree trees into one?
You might want to look at the pavement in front of the cafe. There isn't enough of it and it's upsetting the rest of the pic. In otherwords the whole thing wants to be moved 'back' into the scene to allow more pavement in the foreground. Sorry if this sounds crazy but I'm up to my eyebrows in meds thanks to a chest infection......
Excellent work woodhurst! You've got so much detail in there already and I think what the others have said is all that's needing done. This will be a delight to see when you eventually get it finished and I can't wait to see it when it is. 8) Maybe to get a painted effect you'd have to work on it in post. Catlin
![file_80524.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_80524.jpg)
I dont know if he is really famous or what, but Im re-producing a painting by Mark st. John, called cafe vogue. this is the main thing ive been working on the past couple of weeks. The file size is a beast, takes 7 or 8 mins to save , and crashed when I tried to render it w/ the cobblestone and towers. this is as far as the render got b4 i stopped to work on other stuff. please tear this apart and tell me what i can do to get it to look more like the painting!!!!!!!!!!!!!!!
