Sat, Jan 11, 10:11 PM CST
Subject: Very new to Vue - how do I make the terrain line disappear?
A_ ( ) posted Sat, 18 October 2003 at 10:32 AM ยท edited Thu, 12 December 2024 at 3:15 PM
Hello, I've a question. Every time I render a terrain on a ground plain, instead of a smooth landscape I get a line which indicates where the terrain ended and the ground plain is showing. Texture on both is the same. How do I get rid of it?
YL ( ) posted Sat, 18 October 2003 at 10:54 AM
Just try to move "clip" (or "cut"?) slide in the terrain editor Also, your problem seems to indicate that the terrain is under the default ground plane, maybe just select the ground plane and delete it... Yves
BigGreenFurryThing ( ) posted Sat, 18 October 2003 at 11:08 AM
Here's how to clip your terrain.
Firstly, double click on your terrain to bring up the terrain editor and follow the instructions in the graphic above.
Cheers,
Mark
BigGreenFurryThing ( ) posted Sat, 18 October 2003 at 11:09 AM
Next adjust the clipping rate. Again see instructions on the grpahic.
Cheers,
Mark
BigGreenFurryThing ( ) posted Sat, 18 October 2003 at 11:18 AM
And finally.... Now save the scene quick! Further info is in the manual p165 - Clipping Terrain Altitudes p257 - Clipping Terrains / Making a Stone Arch. Have fun.
Cheers,
Mark
lululee ( ) posted Sat, 18 October 2003 at 11:34 AM
Thanks for the great info BigGreenFurryThing. I appreciate this too.
A_ ( ) posted Sat, 18 October 2003 at 12:46 PM
Oh, thank you very much! :)
megalodon ( ) posted Sat, 18 October 2003 at 10:21 PM
As do I BigGreenFurryThing - something that I haven't quite gotten to in the manual. This will be very useful. I look forward to your tutorials when you get them completed. Megalodon
BigGreenFurryThing ( ) posted Sun, 19 October 2003 at 9:13 AM
Thanks. It's also possible to hide the square base of the terrain by moving it below the ground plane but that's no use if you are combining terrains or using them as models. I'm trying to get the training CD together ready for early New Year. It'll likely include tuts like above plus movies for the tricky bits. :-)
Cheers,
Mark
Tintifax ( ) posted Tue, 21 October 2003 at 8:46 AM
Thanks for this valuable hint. It also helps to create waves/foam on certain places. Lowering the terrain doesn't help here.
