Wed, Feb 26, 4:19 AM CST
Subject: when one needs answers he can always turn to the wise & the slick bryce users
mind2mind ( ) posted Thu, 03 August 2000 at 11:41 PM · edited Tue, 25 February 2025 at 10:43 PM
AWWRIGHT - an answer to a humble call! 1000 cool points!! how do you cut off the bottom of your object in the terrain editor? (this is a first attempt to do greyscale modeling) i swear to god i'm not stupid & here is the bryce interface going "yes you are - muhahahahahaaaah!!!" thanks in advance for your wisdom
Quikp51 ( ) posted Fri, 04 August 2000 at 12:36 AM
The slider to the right is the Clip tool , move it to clip off your terrain and lattice bottoms.
Quikp51 ( ) posted Fri, 04 August 2000 at 12:37 AM
Or is called the Crop tool , I don't recall.
Caligula ( ) posted Fri, 04 August 2000 at 2:00 AM
I think it's the clip tool. Actually (now reading the manual), it's called the Clipping Bracket! Sarah
clay ( ) posted Fri, 04 August 2000 at 8:45 AM
Also on the clipping bracket: if you drag the bracket from the bottom it clips(red) if you drag it from the top the brightest whites on your terrain will turn yellow, what this is doing is making all the highest white levels perfectly flat.Great for making Mesas and Plateus.
Do atleast one thing a day that scares the hell outta ya!!
Hawkfyr ( ) posted Fri, 04 August 2000 at 10:50 PM
and hold down ALT while clicking on the clipping bracket to re-set it. Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
