now your render is very dark with my taste,reduce anbient down more and put some lights behind from your camera,i want to see more clear your foreground:)Look like now like sunset time.....you need a point light maybe and infront of your terain near Benettor
Thanks all. I'm learning a lot from you. WOW! I just looked at this on my computer at work. It seems MUCH darker here than on my monitor at home. $@&% cheap monitors at work LOL. I cant see ANY of the terrain details here but I could see them fine at home. One question, how can I separate one leaf from a tree and use it elsewhere? I'd like to scatter some leaves around. The default tree trunks in Vue 4 Pro look too perfectly round for my taste. They look like plumbing to me. One trick I learned is to take them into the plant editor and vary the scale of the bark texture. This will make the trunks look not so perfectly round.
I received a lot of good feedback on the first version. For those who haven't read it:
nish liked the colors but not the lens flare and suggests working on the terrain textures.
Montanan says sharper textures up front would be nice.
Tintifax suggests that I lower ambient light levels and place more lights mannually to make the tree trunks and terrain pop better.
timefighter agrees with nish about the lens flare.
So I did a combination of all of those suggestions. I'm still not satisfied with the terrain textures and I'm hoping some of you may have some more suggestions to make it work better.
