Your first question: 1. Load and position the prop. 2. Parent the prop to the relevant body part. 3. Save the prop. You will be asked if you wish to save it as a Smart Prop. Answer "yes". That's all there is to it. Second question: 1. Load up the original prop and do all the above, but parenting to the other hand. 2. Save this version as "SmartProp Left" or some such. That should do it.
I know how to parent an object to a body part but that only means that the object moves when the body part moves. What I want to know is there way to smart prop the gun/sword/ect.. to the hand/etc.. without having to move it around everytime you bring it into poser? I waste more time doing this than just about anything. By the time I get the item properly positioned my inspiration is gone. Is there a formula for the x y z dials for the different characters available; i.e. Mike, Vicky, Don, Judy? Also on the same track I have another question. If you have items that are smartpropped to the right hand of a character is there an EASY way to switch it so that the left hand is the smartprop target? I have tried changing the parent but as I stated earlier all that does is make the item move from its original position in conjuction with the left hand. Any help would be greatly appreciated. -OUTLAW-
"I try to save one life a day, its usually my own."
John Crichton
