yes, there's a difference. you need to keep your texture names less than 20 characters including the letters .jpg or the mat files won't find the textures and poser will hang. love esther
I aim to update it about once a month. Oh, and it's free!
X, just to clarify on the pathnaming issue a bit... Inside your MAT files, where the texture files are referenced, if you see anything like: "c:Program FilesPoserRuntimetexturesxocstufffilename.jpg" ...you should replace them with the following style, relative to the Poser directory (strip off the first part of the path up to Runtime) and using colons instead of slashes... ":Runtime:textures:xocstuff:filename.jpg" Cheers, - Keith
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
Good point from Spanki, here. I had this kind of issue several times in the past. All I had to do in those cases was to open the cr2, hr2 or pp2 in BBEdit and changed the lines "c:Program Files:Poser:etc..." to "Runtime:textures:etc...", as Spanki wrote above. Well, as you can see, no major problem, anyway...:-) Regards
I'm working on a freebie package for the M3 Body Suit. It'll consist of .jpg textures and MAT files for applying them. When I'm ready to upload it, I'd like to accurately note what platforms it'd work on. Does the Mac version of Poser read the same type of MAT files that PC Poser does? Is there some difference in the directory structure I should be aware of? I'm not sure what determines the difference as regards platform compatability. Any guidance from those who know would be appreciated.
