Fri, Nov 15, 12:34 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: need little props to electrostimulate my figure
kyo ( ) posted Wed, 22 October 2003 at 9:20 AM ยท edited Thu, 14 November 2024 at 10:47 PM
hi ! talented 3d modellers needed.. as you can see in the pic, i'm looking for a realistic effect to illustrate a medecine book for electrostimulation device : with electrodes applied on skin in differents part of the body... my first try was to paint directly on the texture (pic below) but you can see the stretched effect in the corners of the electrodes square : not good :-) then , i'm asking to me how to realize the more realistic effect, well, props will be the good answer... what i need : a rounded square 5x5 and a rounded rectangle 5x10 with the ability to curve in a horizontal and vertical way, or another solution for a perfect skin-electrode contact curvature if i enable the collision detection.... but i'm definitely not a 3d modeller even for such easy-to-do pieces, if someone could build it for me or give a good tutorial it will be a time saver for me... thanks to anyone and keep up the good work with poser :-))
ockham ( ) posted Wed, 22 October 2003 at 11:05 AM
Attached Link: http://ockhamsbungalow.com/MiscProps/SquarePatch.zip
Here's a prop that should do the job. If you're familiar with using Python, I have a script (not quite finished) that can shape the patch to fit the body. It's not automatic, but it can do this kind of fitting. Talk to me by IM if you want to try it.
My python page
My ShareCG freebies
kyo ( ) posted Wed, 22 October 2003 at 3:57 PM
thx, i just see your post now, i try this and reply in few time
kyo ( ) posted Wed, 22 October 2003 at 4:30 PM
well, your patch props is a good thing to start a realistic job, i had just used some python script pre_made before, I'm interesting to try your script altought .. i have seen others way to fit meshes for clothes especially when the clothes not conform to the figure, may be a other way to do (i believe it transfer meshes surface of body to clothing prop, but i'm not sure...) PS : i had recently uninstall all kind of messenger soft because of some bad viruses,but i can reinstall one if you need to talk directly, just tell me wich one... an your ID i work in swiss.
PandaPride ( ) posted Wed, 22 October 2003 at 7:53 PM
oh duck tape, hummmmm wonder what he's been up to~~~!!!! :O)
kyo ( ) posted Thu, 23 October 2003 at 2:38 AM
any help very much appreciated thx.
