Forum Moderators: RedPhantom
Is that the one with the Brussel's Baby (or whatever he is really called? The punster in me is trying hard to link fountains and little green vegetables!) I suppose it could be used for kinky stuff... but so could those females held in bondage. If that is marketable here, I don't see why a peeing baby based upon a famous statue should be pulled. Carolly
hauksdottir, it's properly named "manneque pis". Yes, really.
Yes it is the one with the "pissoir" fountain statue, but it is just pictured as an example of use. I got it installed okay, but not sure what to do with it, or if the file is right. On auto-install by the paths in the zip it extracts all files including the object files. textures, etc., into the same directory...don't remember ever seeing that. There is a readme file but all it has in it is the usual distribution/commercial usage stuff.
It was not pulled because of the manneque pis - it also featured women's nipples squirting liquid in the thumbnail. We had complaints about it, and I had to agree that the thumbnail was a bit over the edge. Had it been just the manneque pis, or if it had also featured things like a water fountain, etc., then it wouldn't have been an issue.
Second is a set of nipple "caps." They also conform to the default Vicky nipples and would presumably present the same problems with breast/chest morphs. These are a unique and definitely fetish oriented item. Each "cap" has afolding plastic tab type plug with a morph for opening it. Presumably, you can use them in conjunction with the mllk burst figure. There are two material zones, one for the cap and one for the base. The bases (labled Non-Clear L & R) can be made transparent or set to a different color from the caps. Strangely, as supplied, one base is pink and the other is yellow by default. I imagine these items would look spiffy with a metallic reflection. You could alos possible incorporate them as part of a vinyl/leather/pvc fetish type bra.
well it didn't bother me when I approved it .. shrug Thought it wasn't in the best of taste, but there are those who want this sort of thing. The other props included are quite useful though. However it appears that the thumbnail bothered some people and it was removed. Silly, but there you go. I do hope the maker reposts it with a different thumbnail ... Lyrra
'Tis far easier to be offended at the actionsattitudesbehaviors of another, than it is to deal with one's own internal issues. Glad I got this one before it went bye-bye. =Lots= of uses for fluidic props outside of blood, semem, and breastmilk. And those caps are ideal as tops for 'sports drink' bottles. Think about it...
Thanks for all of the great feedback, gang...and especially to lmckenzie for detailing the useage. The problem with all of this 'censor-upset' stems from the same thing we have in business, sports or anything...the 3D community is a melting pot of cultural and ethnic perspectives...each with a different viewpoint of what is acceptable. And on the other side of the coin is the psychological/religious babel, when people see something that stirs up thoughts they feel they need to suppress...remove the cause and the 'mind warp' goes away. Blessed is the person who can look at something they find distasteful, shake their heads and say, "Oh well, to each his own", and leave it at that.
Right, Dale B. the caps would be perfect for a bottle. They do come as a pair though so you'll have to figure out how to delete one and still keep the open morph if you want it to be functional. You could also use it as the air vent on a blow up doll I suppose - more kinkiness, true but creating a blow up morph figure would be a nice challenge for someone. Fishnose, your "high pressure" account is priceless. No wonder some places don't want women breast feeding in public - it could be hazardous to bystanders :-) I suspect that the main thing that rubbed someone the wrong way about the thumbnail was the fact that she was squeezing her nipples to expel the milk. A good old fashioned breast pump might have been OK but that looked too much like she was performing a non-essential function that might conceivably be fun I suppose. If you visit Terrace's site, be sure to get the Terra scene. It's a really nice cyclorama type environment prop.
!!! =Damn= the lack of breathing morphs on nigh onto every model! Clothify Judy over a couple hundred frames, render to stills and compile in reverse order, and you'd have your lovedoll inflating! But it would be no -fun- without the inflator having to work for it! >:)= As for the expressing of milk being 'fun'.... Maybe so, but talk to those who nurse about the consequences of -not- clearing the ductwork regularly. =Not= pleasant.
Attached Link: http://babu.com/~heaven4d/
I'm glad I grabbed it before it vanished .I got it installed ok with a little thought..I have Poser4. It does take a little bit of experimenting to figure out just how to get the best use from it, but If a dummy like me can figure it out, I'm sure most should be able to. As for the thumbnail being pulled..I would have prefered that it be left. But, seeing it HAS been pulled...maybe the originator could repost with a less..??Obvious?? thumbnail ?
Anybody else d/l this prop and figure out how to use it? There was no readme on how to use it, and I see now the file has been removed from the freestuff board. I can usually figure this stuff out, but this one has me stumped. It was created by Nekote and distributed via Terrace's site. The promo thumb made it look a bit like a 'kinky' prop, but I can see many more uses for it if I can figure how to work it!
