Tue, Jan 28, 5:48 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Poser 5 and Lights problems.
disneyfabfive ( ) posted Mon, 27 October 2003 at 2:36 PM · edited Tue, 28 January 2025 at 5:34 PM
I have a few lights that everytime I apply them they freeze up the render. Even if I am just doing a quick poser 4 draft render to check how they will look. It gets to the loading textures and never leaves that screen. I have waited up to 20 minutes just for a draft render. I am running xp with 512 ram with a Radeon 9600 128mb video card. Thanks for any help, Beth
dialyn ( ) posted Mon, 27 October 2003 at 2:48 PM
One thing to check is to make sure that you delete any lights that are "off" (they will show as black dots). Try deleting all lights before applying a light set...and the fewer lights the better until you get a feel for Poser 5. Traveler at RuntimeDNA has excellent light sets (for free) that never cause a problem (as far as I know).
smiller1 ( ) posted Mon, 27 October 2003 at 3:02 PM
If you haven't loaded the SR3 patch, do so. That fixes a number of light problems.
timoteo1 ( ) posted Mon, 27 October 2003 at 10:34 PM
There is still an issue when rendering animation, even after SR3. Lights will sometimes become animated by themselves, after making a change at a certain keyframe. So always, before commencing your render, check to make sure the light(s) did not add their own keyframe and if so, naturally delete it. Also, unchecking/checking ANIMATED under a light's properties will not always "stick." Not sure why, but P5 switches it right back. -Tim
starmkr ( ) posted Wed, 29 October 2003 at 10:27 PM
I am getting the same problem. I just bought Poser 5 and added service pack 3. I have AMD 2800 with 1 Gig of Ram and media hard drives. I was only using Vic 1, background picture and Volts Light which I have used over and over on Poser Pro. The render keeps freezing.
