Sure ... first ... Go to [menu]:
"Edit" ---> "General Preferences..." --->"Display Units" to Feet
Then ...
Open the Camera's properties and set yTran to 6.000 (feet).
Double click on the yTran parameter dial to open the Parameter Settings window and set the Min and Max values to 6.000 - then "Use Limits."
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://www.renderosity.com/messages.ez?ForumID=10139&Form.ShowMessage=1508970
Good tip, geep. It works well. Now..... perhaps you can answer my question in the tech forum. How do I change a camera's center of rotation to get a panoramic swing around a room? macThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
In Poser 5, is there a way to lock the height of a camera a fixed distance from the ground? I created a room, and I want to be able to set the camera at eye level (about 6 ft) and lock it at that height but still be able to move it around the room. Also is there a way to figure out distances,in feet,in poser?
