Tue, Nov 26, 6:33 PM CST
Subject: Export files
rkoenig ( ) posted Mon, 03 November 2003 at 2:05 PM ยท edited Tue, 26 November 2024 at 6:30 PM
Hello! I bought now Vue ESPRIT professional! Now i would like to export an object to an other format(file) type( cinema, 3dmax oder 3dstudio) but this following error message comes: SORRY, THE SELECTED OBJECTS HAVE BEE LOCKED FROM EXPORT. THEY CANNOT BE EXPORTED! What now? What can i do? How can i unlock this Objects? this objects are all for free use! I heard that its possible to unlock this! but how? Please help, thanks a lot and greetings from switzerland! sorry for the bad english! Geroge
gebe ( ) posted Mon, 03 November 2003 at 2:34 PM
This means that you have probably a Pz3 imported Poser figure or object you want to export?? You cannot unlock it. If you want to export an object from Vue, it must be 1. a Vue object or 2. an imported OBJ object. Have a look at this thread: http://www.renderosity.com/messages.ez?ForumID=12368&Form.ShowMessage=1506670
rkoenig ( ) posted Mon, 03 November 2003 at 2:44 PM
Hi! I downloaded some Objects from RENDEROSITY, so i think they are .VOB file type! Some of the downloaded files i can export as .3ds but some other Objects i cannot export because this error message is coming! What can i do?
davidrivera ( ) posted Mon, 03 November 2003 at 4:05 PM
As far as I know you cant export Vue 4 VOBs; you can only export Vue Pro VOBs. I had imported an obj object into Vue 4 I then saved it as a VOB. I was able to load VOB into Vue Pro but could not export it. To make the VOB exportable I had to bring the original obj into Vue Pro and then save it as a VOB.
Dave
rkoenig ( ) posted Mon, 03 November 2003 at 4:29 PM
Ohh good! so i have no chance to export a VOB file? What i can do? It really sucks! greetz
rkoenig ( ) posted Mon, 03 November 2003 at 4:39 PM
Its me again! Can I Export a VOB Object back to .Obj ? Once I heard to manipulate the dll of esprit and insert the .3ds code! I need to export the Objects! But i downloaded now some ESPRIT 4 VOB files! And some of them i could open! Ohhh good! What can i do!? Thanks!
Tiny ( ) posted Mon, 03 November 2003 at 6:58 PM
I also had problem exporting as .obj file. I was able to get around it somehow when I selected all parts of the object (if it concists of several parts). Grouped it and did a right click, choosed 'Bake polygons' (or something like that). After that I was able to export it as .obj file.
I'm not sure if it is the way to do it... but worth a try. :o)
Be sure to save the original first since it becomes one object.
Tiny
wabe ( ) posted Tue, 04 November 2003 at 12:42 AM ยท edited Tue, 04 November 2003 at 4:25 AM
Hey, simply right-click onto the object (ctrl-click for Macians). Select edit object and there - tata - you can select allow export. Then it should work. I tried a Poser object from DAZ, worked like that as well. try it out!
gebe ( ) posted Tue, 04 November 2003 at 2:16 AM
Read the grey field page 112 in the Vue Pro book:-). BTW Walther, all objects doesn't show the EDIT OBJECT when you right click and many objects cannot be exported. I already said it:-) Guitta
gebe ( ) posted Tue, 04 November 2003 at 2:40 AM
"Maybe we should find out why some objects can't be edited Page 112 grey field:-) I cannot export the housemouse from Daz (or any other Poser figure) after I have imported her as a pz3. Only if imported as OBJ it is possible. :-)Guitta
grunthor ( ) posted Wed, 05 November 2003 at 11:17 AM
I believe this is a feature to protect the artists copyright, not a bug.
