Thu, Nov 28, 3:46 AM CST
Subject: M3/Freak full body morph, advanced question
object22 ( ) posted Tue, 04 November 2003 at 8:15 PM ยท edited Thu, 28 November 2024 at 3:41 AM
Is it possible to somehow save the Freak body form as a full body morph and apply it to M3 so he can morph into Freak? Thanks in advance for any responses! =)
wolf359 ( ) posted Tue, 04 November 2003 at 8:29 PM
why bother if you already have the freak just use him. :-)
My website
object22 ( ) posted Tue, 04 November 2003 at 8:39 PM
I do animations and I want to morph M3 into the freak during the animation.
pdxjims ( ) posted Wed, 05 November 2003 at 7:53 AM
If you go into the .cr2 file for the Freak, and copy the channel information used by the injection morphs, then paste them into the M3 .cr2, you can get M3 to take the Freak injection poses too. I copied the head channels from the freak, and then injected the face morphs, and it worked great. I'm oging to try it with the various full body moprhs next. Here's M3 with the Freak Ogre head morph. I wonder if it'll work with the V3 head morphs too...
pdxjims ( ) posted Wed, 05 November 2003 at 9:36 AM
Copying the full body morph channels and teh group channels that go with them from teh Freak to M3 worked, sortof... Since the morphs are based on the Freak, they all look a little strange on M3 unless you also use a to-Freak original morph set described above. This said, you do get some interesting effects. Copy the channels for Wirey from the Freak to M3, then set them at a negative .5 to 1. Suddenly you get a new muscular morph. Actually pretty neat. The head morphs for Superhero and Comic Superhero also look good at a negative setting, while at a positive setting they look pretty strange. The V3 transfer didn't work. I'm still thinking that one out.
OneShot ( ) posted Wed, 05 November 2003 at 1:25 PM
See what happen when you don't 'Floss' Sorry couldn't help myself!
rreynolds ( ) posted Wed, 05 November 2003 at 4:28 PM
Is there any shortcut to copying channels? Some of the body morphs appear in 50 locations, so that's a fair amount of work to copy them one by one. Did you have a program to automate the process to make it simpler? The head morphs can be copied over with Morph Manager and worked fairly easily. Body morphs span more than one part, so it's a lot more effort copying and pasting.
pdxjims ( ) posted Wed, 05 November 2003 at 5:57 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=533694
First, don't worry about the fingers. They don't really have much to do with the morphs. Second, all the morphs for each body part are named the same, so copy the set from the Freak, then just keep pasting. 1 copy, 20 or so pastes. I use Zpad, so I can jumo to the propper place pretty easily. Vim with the Poser plug-in should let you do the same thing.
VI_Knight ( ) posted Thu, 06 November 2003 at 10:52 AM
