Forum Moderators: RedPhantom
Copying the full body morph channels and teh group channels that go with them from teh Freak to M3 worked, sortof... Since the morphs are based on the Freak, they all look a little strange on M3 unless you also use a to-Freak original morph set described above. This said, you do get some interesting effects. Copy the channels for Wirey from the Freak to M3, then set them at a negative .5 to 1. Suddenly you get a new muscular morph. Actually pretty neat. The head morphs for Superhero and Comic Superhero also look good at a negative setting, while at a positive setting they look pretty strange. The V3 transfer didn't work. I'm still thinking that one out.
Is there any shortcut to copying channels? Some of the body morphs appear in 50 locations, so that's a fair amount of work to copy them one by one. Did you have a program to automate the process to make it simpler? The head morphs can be copied over with Morph Manager and worked fairly easily. Body morphs span more than one part, so it's a lot more effort copying and pasting.
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=533694
First, don't worry about the fingers. They don't really have much to do with the morphs. Second, all the morphs for each body part are named the same, so copy the set from the Freak, then just keep pasting. 1 copy, 20 or so pastes. I use Zpad, so I can jumo to the propper place pretty easily. Vim with the Poser plug-in should let you do the same thing.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Is it possible to somehow save the Freak body form as a full body morph and apply it to M3 so he can morph into Freak? Thanks in advance for any responses! =)
