Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Have you tried it without Mike 3 in the scene? I don't think it's the cause though, as P5 should eliminate crosstalk, but it's my only guess :o)
jerr3d, I think I saw on the DAZ FAQ or something that that happens on certain systems. If my memory is intact, I think it said you should set things up like you want and then use the dial cleaner to reduce the file size. ernyoka1, I understand there is still a cross-talk-like problem with P5, at least with the new millennium figures that use the injection morphs. I read a thread about it, and this is apparently my problem, but I need to do a little more research. elgyfu, the morphs in question are the simplest imaginable, like MouthOpen (or is it OpenMouth?). Thanks for the feedback. Later.
Afaik DialCleaner does nothig to file size. All it does is to hide the unused dials. They're still IN the cr2, just invisible. But I may be wrong again :o) Are you using the M3 expression morphs that came with the Freak? I don't know if they're the same as the M3 expression morphs that came with M3 (confusing isn't it?) becourse I have moved all my M3 morphs to a PBooost-bank called M3Morphs, and the Freak ones are in the Freak folder :o) That's why I don't know if they're the same. But I have had trouble making injection morphs work AT ALL in P5, so I have a character loaded with all morphs (injected in PPP) that I use whenever I feel like tormenting myself with P5 ;o) (Seriously, P5 runs ok on my machine, but notably slower than PPP)
What does it mean if the M3 Expression morphs won't inject for the Freak? I'm using Poser 5 w/ SR3 installed. I've tried this 3 different times after a cold boot. No luck. Could this have anything to do with the fact that I have Michael 3 as a character in the same scene? If I missed posts on this subject, sorry.
