Sat, Jan 11, 7:54 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 11 12:18 am)
Subject: Can't get morphs to inject for Freak.
rdf ( ) posted Thu, 06 November 2003 at 1:23 AM · edited Sat, 27 July 2024 at 7:09 AM
What does it mean if the M3 Expression morphs won't inject for the Freak? I'm using Poser 5 w/ SR3 installed. I've tried this 3 different times after a cold boot. No luck. Could this have anything to do with the fact that I have Michael 3 as a character in the same scene? If I missed posts on this subject, sorry.
TrekkieGrrrl ( ) posted Thu, 06 November 2003 at 2:39 AM
Have you tried it without Mike 3 in the scene? I don't think it's the cause though, as P5 should eliminate crosstalk, but it's my only guess :o)
elgyfu ( ) posted Thu, 06 November 2003 at 9:05 AM
Not all of Mike's injections work. There is a list in a previous thread.
jerr3d ( ) posted Thu, 06 November 2003 at 9:26 PM
That's funny, I inject one face expression and they all loaded!
rdf ( ) posted Thu, 06 November 2003 at 10:16 PM
jerr3d, I think I saw on the DAZ FAQ or something that that happens on certain systems. If my memory is intact, I think it said you should set things up like you want and then use the dial cleaner to reduce the file size. ernyoka1, I understand there is still a cross-talk-like problem with P5, at least with the new millennium figures that use the injection morphs. I read a thread about it, and this is apparently my problem, but I need to do a little more research. elgyfu, the morphs in question are the simplest imaginable, like MouthOpen (or is it OpenMouth?). Thanks for the feedback. Later.
jerr3d ( ) posted Thu, 06 November 2003 at 11:28 PM
Oh, I'm not really complaining about it, I was just surprised. The Freak is a very cool figure, and he was free! (more or less)
TrekkieGrrrl ( ) posted Fri, 07 November 2003 at 12:44 AM
Afaik DialCleaner does nothig to file size. All it does is to hide the unused dials. They're still IN the cr2, just invisible. But I may be wrong again :o) Are you using the M3 expression morphs that came with the Freak? I don't know if they're the same as the M3 expression morphs that came with M3 (confusing isn't it?) becourse I have moved all my M3 morphs to a PBooost-bank called M3Morphs, and the Freak ones are in the Freak folder :o) That's why I don't know if they're the same. But I have had trouble making injection morphs work AT ALL in P5, so I have a character loaded with all morphs (injected in PPP) that I use whenever I feel like tormenting myself with P5 ;o) (Seriously, P5 runs ok on my machine, but notably slower than PPP)
rdf ( ) posted Fri, 07 November 2003 at 1:16 AM
I will have to check on the M3 expression morphs versus the M3 expression morphs thing ... :( Anyway, thanks for the character loaded with all morphs suggestion. Though I've come across other advice in other threads, it may ultimately come to that.
