Sat, Dec 28, 5:48 AM CST
Subject: try again (LW model/tex import to Vue)
aussie-3d ( ) posted Wed, 12 November 2003 at 4:31 AM ยท edited Sat, 28 December 2024 at 5:15 AM
Testing LW models & tex import to Vue. Model is fully UV mapped all sides, however front only has these lines?, back with different tex of same type (used jpg and bmp), no lines. also mapped using uvmapper, same result, imports to poser okay and with no lines. Any LW's out there importing to Vue who can offer assist please. Ta. vue 4.12, P4,Ti4600,17MB tex. Also sorry for the below deletes images were 500K large
MixedNut ( ) posted Wed, 12 November 2003 at 6:16 AM
Hmm....okay, this is a new one. Just a thought - does this object of yours have any depth? I can't really tell from the picture. Vue may become confused if an object is zero-depth.
DMM ( ) posted Wed, 12 November 2003 at 10:40 AM
I agree. Thats the sort of look you get when two objects are at exactly the same place, which would be the case if those two polygons are in the same place but pointing in opposite directions. I take it they are different polygons, not the same polygon but 2-faced? If so then move one a miniscule amount away from the other.
Benettor ( ) posted Wed, 12 November 2003 at 2:26 PM
look your mat files ... maybe you have very big bump value.... reduce your bump map for all your textures down..when you import in vue... maybe is this the problem... look the bump tabs for all your materials .
  • Benettor - Photographer - My Art
aussie-3d ( ) posted Thu, 13 November 2003 at 1:50 AM
Ta everyone, yep this is actually a box(as just testing some textures and model from Lightwave to Vue), four sided, and no bump map. Image appears a-ok in poser, so unless the LW mapping is screwed or Vue / ahmmmm me, is having a problem as such. am keep on keeping on. ta again all.
aussie-3d ( ) posted Thu, 13 November 2003 at 3:28 AM
My mistake it seems. Vue did not seem to import one object side(poly), with multiple name/mapped details, when remapped with a different LW name and re-tex'd, all ok. My apologies for your time and thanks for the advice anyway. Ta again.
