Sat, Feb 1, 5:05 AM CST
Subject: Changing Screen Size on Vue
bloodsong ( ) posted Tue, 11 November 2003 at 3:46 PM ยท edited Fri, 31 January 2025 at 8:08 AM
heyas; when i installed vue, i was at 800x600, but nowadays i'm at 1024x768. well, my vue is totally confused by this. it either opens small in the corner and under the start menu and needs to be maximized, or it starts an inch below the top of the screen and needs to be un-maximized (restored) and stretched to the right size. any handy trick for getting this thing straightened out? :)
BigGreenFurryThing ( ) posted Tue, 11 November 2003 at 5:56 PM
Attached Link: http://www.annoyances.org/exec/forum/winxp/r1036236055
If the problem is persistent there's a thread that might help at the truly splendid annoyances.org site. URL above.
Cheers,
Mark
Flycatcher ( ) posted Tue, 11 November 2003 at 7:03 PM
The following doesn't sound likely in yor case, but just on the off-chance... Have you installed the latest patch? I had this problem when I first bought Vue, except that the full screen size "stuck" for one load, but then reverted to the smaller size. The problem disappeared when I applied the 4.12 patch (or possibly the one before that).
bloodsong ( ) posted Sat, 15 November 2003 at 3:10 PM
heyas; well, i don't have xp. and yes, i applied the 4.12 and then the 4.2 patch. nope, definitely don't have those keys in my 98 registry.
BigGreenFurryThing ( ) posted Sat, 15 November 2003 at 3:31 PM
Sorry should have asked which OS you use. Doh. Does this happen with other programs or just with Vue?
Cheers,
Mark
jamesd1 ( ) posted Thu, 20 January 2005 at 6:53 PM
When I do a render to the full screen size Vue paints the picture full screen and when done automatically makes the image smaller with scroll bars. How do I change this behavior--I want it to stay full screen after the render until I tell it outherwise, which was the default in vue 4. I did not see a setting. What's up?
nanotyrannus ( ) posted Thu, 20 January 2005 at 7:12 PM
As far as I know you can't change that setting, I know, I'm not sure whether I like this new "feature" or not (been there since Vue 4 Pro), it's nice because I can tell when it's done rendering when I'm working on other projects and all I have to do is look to see if it's stretched or not, but like you I'd like to see the whole render, not just a little window of it. I usually just save it and look at it in windows explorer since I only let the render finish if it's the final one.
