Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 1:40 am)
heyas; if it says 'cant find geometry file blah blah blah,' a couple times then 'you are out of memory blah blah blah;' then you're not outta memory, you just confused poser. the obj file has to be in a specific (and very picky in the upper/lower case department) directory, or else the library file can't find it, and poser can't load it. check the readme for the prop to see where the obj is supposed to be. alternately, you can open the cr2 file and read the directory where it is supposed to be, near the top. also remember if a previously working prop/figure suddenly does this, you probably need to delete the rsr that is next to the obj. if it gets corrupted, the same deal will happen.
It said i need to dedicate more memory to poser. HOw do i do this?
