Fri, Nov 15, 5:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Subject: Curious issue with posettes eyebrows
Drezz ( ) posted Mon, 17 November 2003 at 7:51 PM ยท edited Fri, 15 November 2024 at 5:39 PM
Hey all, was wondering if someone could lend me some help here. I am creating a tex for posette and i keep getting some dark lines under her eyebrows. They dont show up in the tex, and i have no other tex's loaded (bump's, etc.) Ive tried changing colors around and what not, still no go, any ideas anybody?
geep ( ) posted Mon, 17 November 2003 at 8:54 PM
The lines are caused by the basic mesh. You would need to change the mesh to smooth the area using a magnet (morph) or an external modeler. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Drezz ( ) posted Mon, 17 November 2003 at 9:06 PM
thanks, ill try that
Little_Dragon ( ) posted Mon, 17 November 2003 at 10:17 PM
No need to reinvent the wheel (unless you need the practice). You can find a free "smooth brow" morph here:
http://chimeraware.cresswells.com/
Drezz ( ) posted Mon, 17 November 2003 at 11:07 PM
well everything ive tried so far has been for naught. Either it accents the black areas (#2) or the tex map gets streched (#1) Anybody got any ideas?
geep ( ) posted Tue, 18 November 2003 at 12:06 AM
In #1 ... if you modify the mesh, you need to also redo the UV map with the "new" (modified) object, i.e., the head. The old map with the "new" head may cause the stretching that appears in #1. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
ronstuff ( ) posted Tue, 18 November 2003 at 1:37 AM
As Geep suggests, you could flatten the eyebrow mesh to reduce the shading at the edges or you could alter the lighting to reduce it or you could just fix it in post. What you are seeing is the geometry of the eyebrow which was designed back in the days when textures were not very realistic. In more modern figures, The eyebrow is normally transmapped so you don't see the edges of the elevated mesh, but see thru them to the underlying head mesh. Unfortunately I don't think that the P4 figures have any mesh under the eyebrow so if you transmap the eyebrow you see a hole where the head mesh should be.
Mason ( ) posted Tue, 18 November 2003 at 11:49 AM
Actually this is an issue of the high light on the alpha. You need to either eliminate any hilight on the eyebrow or match it perfectly with the underlying geometry.
ronstuff ( ) posted Tue, 18 November 2003 at 3:43 PM
I don't think this is the transparancy issue because Posette has no mesh under her eyebrow, so you can't transmap the eyebrow without seeing into her skull. eeek!
Drezz ( ) posted Tue, 18 November 2003 at 5:22 PM
Wonder if anyone has made a prop or something to correct this issue? hmmmm........
