First, don't let the X1 user id throw you.... this is TalleyJC ...I'm using my girlfriends pc and I didn't realize she logged on last......Ok here's the plan....... I'll create each piece as a separate .obj that you can then import. I don't know how to get Lightwave to export UV's but I will create many surfaces so you can use those to texture in posers material settings. I'll add a little more detail to the scanner, like scanning grids along the interior and maybe something like a control panel to the top. I'll also try to create two morphs for the curtains on the luggage scanner that bends one in and one out so you can animate something passing through
Ok So far?
Has anyone seen or know if anybody has done a airport style metal detector (both the kind you walk though or the thing that you put your bags through??) free or pay(within reason)
