Okay, I need a little more information before I can help you. What software are you using to create your morph targets in? (If you're using Rhino, Traveler has an excellent tutorial on his site - MorphWorld2) Paul
Very, very basically: Open your prop in your modelling application, make the changes and export it as a new .obj file. Open the prop in Poser, select it, double click, add morph target, selecting the file you just saved, click OK. Check that the dial works correctly. With the prop selected, open the Props library, Add to library, overwriting the existing file. When you open it again it should have the morph target included and working. Does that help or am I smoking rope again? :) Berge
I download prop, UltraShoe a few days ago. And saw all those dials. I want to ask, if anybody could tell me how, can I make them, or where I can get good tutorial about makeing props. Because I want to make my own prop with modifiers (morphs, dials). I tried like this: I made prop and saved it in library, then i loaded it again and add a morph and saved it again. But when i loaded it again there is still dial for my morph, but i can change the value in any direction but the prop didn't change. I don't know what and where I do wrong.
