Sat, Sep 21, 8:40 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 8:40 pm)
Subject: CyberMesh and Poser
Bongo ( ) posted Thu, 17 August 2000 at 12:02 AM ยท edited Sat, 21 September 2024 at 6:37 PM
Does anyone here use Cybermesh? I made an object in Photoshop using the Cybermesh (2d to 3d) plugin, but when I try to import it to Poser I get the message " no facet data hence no model created." (and yes the message actually contains the word 'hence'!) I've been HENCED by Poser! Any suggestions??
Kalypso ( ) posted Thu, 17 August 2000 at 1:03 AM
Site Admin
Hmm sounds like what elefont does. What output does CyberMesh give you? I save in .dxf from elefont but it can only be imported into bryce, and then I export is as an .obj from there and import into Poser. Maybe that will work for you too?
Kalypso ( ) posted Thu, 17 August 2000 at 1:15 AM
Site Admin
ok, correction, now that I've tried it out it works and you can just import it into poser. But you have to make sure that the format for output is 3D Face DXF. By default Cybermest outputs NxM DXF. It's an option on your right towards the bottom. Haven't tried the Polyline DXF but I will try some of the others since .dxf files tend to be very big and unmanageable. Good luck!
gideon ( ) posted Thu, 17 August 2000 at 11:41 AM
Where can I find Cybermesh? How does it work in Photoshop?
Kalypso ( ) posted Thu, 17 August 2000 at 1:56 PM
Site Admin
http://www.puffindesigns.com/support/downloads.html You don't necessarily have to use it within Photoshop, when you download you'll see that you can use the utility alone as well.
