Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 3:32 pm)
ok, correction, now that I've tried it out it works and you can just import it into poser. But you have to make sure that the format for output is 3D Face DXF. By default Cybermest outputs NxM DXF. It's an option on your right towards the bottom. Haven't tried the Polyline DXF but I will try some of the others since .dxf files tend to be very big and unmanageable. Good luck!
Does anyone here use Cybermesh? I made an object in Photoshop using the Cybermesh (2d to 3d) plugin, but when I try to import it to Poser I get the message " no facet data hence no model created." (and yes the message actually contains the word 'hence'!) I've been HENCED by Poser! Any suggestions??
