I had the same pb few weeks ago with another one : Swapping to other application (ie or explorer) when the atmosphere editor was open crash Vue.
I report these bugs to e-on and they recommended me to re-install Vue4. And they were right.
I made a standard install (Main Disk C) and upgrading to latest version manually (no auto update).
No more pb with the atmosphere editor.
Thanks gebe and denice for the help. Help is much faster here than at other places. I uninstalled Vue Pro and reinstalled and it is working much better with out a few the problems I been having. No more crash with atmosphere editor and now it is finding my pz3 files from poser 5 as it should. I upgraded manually with only the last update bypassing the one in between. :o)
ïÏøçö
Working with a saved imge in Vue Pro I go into atmosphere editor and go to fog and haze using standard atmosphere setting.
When I click on Color to change in Fog I get an error and Vue Pro Crashes.
Reopen and do same with Haze color and crashes the same.
Curious if anyone else is having this problem with the new update.
The error is: Vue4Pro.eon.exe has gererated errors and will be closed by Windows. You will need to restart the program. :o(
ïÏøçö
