Forum Moderators: wheatpenny, Deenamic Forum Coordinators: Anim8dtoon
Photography F.A.Q (Last Updated: 2024 Nov 01 10:53 pm)
Maybe you could try PNG and see how the colors hold up in that.
What is a friend? A single soul dwelling in two bodies. -
Aristotle
Glass Eye Photography =- -= My Rendo Gallery =-
Color change? That's not usually a sign of JPEG compression. How are you saving the images? It kind of sounds like a colorspace issue. I had the same problem when I first started using AdobeRGB as my colorspace. Was saving as JPEG and there was a serious shift in colors. I found I had to convert my colorspace to sRGB first to get a good approximation. The biggest problem is that if you save for web, you will never get the exact colors because web browsers don't color manage. -=>Donald
Randy - Just remember, if you are sending the jpeg up onto the web, using Save for Web is the way to go. If you just save it as a normal Jpeg under SAVE AS then you also get a bunch of stuff appended to the image in the header that can effect some people using certain browsers (the image will either not display or in some cases can lock up their browser). -=>Donald
I'm having problems maintaining the original colors of an image after I compress it into JPEG. Is there a better way of of doing this rather than manipulating the original to adjust for the JPEG? I'm currently doing it by trial and error.
