Attached Link: http://www.e-onsoftware.com/Support/index.php
I would contact E-ON for this issue. Sounds like there might be something wrong with their update.James
Vue Coordinator
Attached Link: http://www.e-onsoftware.com/Support/ShowMessage.php?id=1070601716
Thank you James for your response and link.Sorry, I'm used to the British/North American convention where '.' denotes a decimal point. However, I would not assume it is not your ISP. Corruption in a large file download can occur in many places along the pipeline and, unfortunately, can be very hard to diagnose (assuming you are the only one with the problem).
If they ain't broke.... No, so long as VuePro can find all your cows, it will run the update automatically. It's just a matter of the fact that you -can- do it manually, if the main app is acting up. If there was a needed update in the beta pack, then when you run HyperVue, it will update all the cows it finds. Mine haven't, so I'm assuming the Cows are stable at the moment, and the fixes all involve the main program....
