Sun, Jan 26, 8:22 PM CST
Subject: O.K. now I've done it...help
skee ( ) posted Fri, 18 August 2000 at 10:08 AM ยท edited Mon, 20 January 2025 at 12:14 PM
I've been play with the control keys and have my poser interface in poser 3 screen, how do I get the poser 4 interface back? I'll quit messing with the keys I swear... skee (the monkey)
NOTE: No trees were killed in the sending of this message, but a large
number of electrons were terribly inconvenienced.
LoboUK ( ) posted Fri, 18 August 2000 at 10:13 AM
Try "ESC" or "PO4" - either of those should work. If not, simply tell Poser to start up with the factory presets and restart it - that ought to work Paul
skee ( ) posted Fri, 18 August 2000 at 10:19 AM
thanks I'll give it a try. skee
skee ( ) posted Fri, 18 August 2000 at 10:43 AM
Paul, None of the above thing worked. I also now have extra folders in my poses and figure files that are listed as "X" that I can not get poser to read. If I do a reload of poser4 will I need to repatch?
Nance ( ) posted Fri, 18 August 2000 at 7:06 PM
Before you reload try going to: "Edit/General Preferences" and check "Launch to Factory State" and re-open Poser. That should get you back to the P4 interface. I don't know about the new folders thing though. Is there anything in them?
skee ( ) posted Fri, 18 August 2000 at 7:34 PM
Nance, I have tried to do that but does not work. and yes the folders have copys of all the figures I have downloaded and all the poses that I have gotten off this site. But I can't use the folders, it says "can not find obj" and will not load. strange ,huh! A picture of them shows up in the sidebar images but want load. Thanks for any help. skee
skee ( ) posted Fri, 18 August 2000 at 7:56 PM
nance, I just took another look at the folders and from what I see they contain a list of everything in each file( under poses X is a list of all my poses ALL OF THEM, under prop x there is a list of all my props ALL OF THEM..wild !!!! But on my hard drive under Props ect. on folder x . The picture I see is the gray guy ,you know the one with his hands up, when it doesn't have an image. skee
Dave Wight ( ) posted Mon, 21 August 2000 at 11:09 AM
In the prefs folder is Poser.ini. In it you will find a line that says: USE_META_UI 1 Actually, yours probably is set to 0, change it to 1 & you'll be back to normal, whatever that is.
Nance ( ) posted Mon, 21 August 2000 at 9:21 PM
Now thats a handy bit of info. Did that restore it Skee?
skee ( ) posted Mon, 28 August 2000 at 10:59 AM
dave wight, thanks for the help. it seemed to do the trick. sorry it took me so long to get back, I have been out of town for a week of R&R and my wife would not let me take my computer with me. nance , it worked, thanks for your concern. ever grateful skee
