Kat, In the Toon settings, try turning the toon settings to zero and the "Line" settings to 50% or so. Also play with the "edge" angle settings (low settings probably.) Have sharp edge at "1" as well. I also found if you render a big image the black lines are thinner. I just started playing with the toon settings as well. Good Luck, Regards Mike
Attached Link: http://www.visionized.com
![file_87800.png](https://live.cdn.renderosity.com/forum/_legacy/file_87800.png)
I'm having a problem getting a handle on the settings. I want to get this result within C3, right now I'm using Strata 3.9 RavX render to get this....I'd like to stay inside C3 for the whole project. Anyone have the settings or know how to get it?THANKS in advance.
Kat
