Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 4:45 pm)
Attached Link: http://www11.brinkster.com/shaaz/show.html
Oh the image on the LEFT is the result & the RIGHT is what I am aiming for!!!!!!!What figure are you using, and are you using Poser 5's face room? If so, I recommend you put that aside for a while, start with a figure with a lot of morphs, and play with dials. Several people I've come across have said they get better results working with the morph dials than they do with the face room.
If you try just using the front photo in the face room you can get much better results. I did that with a few things that did work. You can use morph putty to do the things that you would normally do using the side photo. You need to fix the black areas in the finished texture but that is quite an easy thing to do.
I want to make a custom head from a image. Is it possible to create textures for heads & map them to poser OR another drawing tool is needed for the mesh/polygons. I have been trying to textureize, scan faces & morph heads. But all to get real bad results, OR no such realistic work? I have a link setup below where you can see my result, please comment on what am I doing incorrectly or what should be done desirably! Thanks Shaz
