Sat, Feb 8, 7:47 PM CST
Subject: Morphing Props?
LadyBea32 ( ) posted Sun, 07 December 2003 at 8:51 AM ยท edited Sat, 08 February 2025 at 7:45 PM
is there a way to get a prop to morph open? i need some drawers to be able to do that. right now they are set as a figure, but i would like to have it set as a prop so it can accompany the other props that go with it.
iamonk ( ) posted Sun, 07 December 2003 at 10:55 AM
I just tried this out with a couple of boxes and it worked.
You have your props assembled, "drawers closed"...
Export as an .obj, select all parts of the item,
no boxes checked in the following dialogue.
"open" your drawer, then export all as one again.
You will need to do this for each drawer, one drawer open at a time.
Import the first, use the second as a morph target.
When you are all finished you'll have a slider for each drawer.
Like I said, I quickly tried this and got a slider to make the "drawer" open and close.
You can also put limits on this so the drawer stops where it should.
LadyBea32 ( ) posted Sun, 07 December 2003 at 1:23 PM
k im a tad confused without seeing pictures but im gonna try this anyway. seems easy enough, but im almost brain dead at the moment...hehe thanks hon for your help bea
iamonk ( ) posted Sun, 07 December 2003 at 3:15 PM
Ok, assuming you have everything back to individual objects...
iamonk ( ) posted Sun, 07 December 2003 at 3:22 PM
You have just exported the base for the new morphing prop. Before you get rid of anything, you will need to make your morphs.
If you don't close the drawers correctly, they will move when you open the other drawers.
Using the same export settings, create an .obj for each drawer. You will be exporting the whole thing, not just the drawer.
LadyBea32 ( ) posted Sun, 07 December 2003 at 3:24 PM
ohh ok, i got ya now. thanks so much. i had unchecked everything in the export box...hehe hug bea
iamonk ( ) posted Sun, 07 December 2003 at 3:27 PM
ONLY when you are done with ALL your morphs, you can clear your scene and import the first .obj that you exported.
These will be the import settings.
iamonk ( ) posted Sun, 07 December 2003 at 3:34 PM
Now you have a rigid prop that will not open. Load each of the other .objs that you exported as a morphtarget, name them drawer1, drawer2....
When you are all done you can save to your Props folder so you won't have to do all that again.
If all went well you will have a chest that will open it's drawers with a flick of a dial.
Hope this helps.
LadyBea32 ( ) posted Sun, 07 December 2003 at 3:36 PM
k i tired your way and got totally lost with it. i well have to play with that technique. then i tired something off the top of my head. i remembered that i can save multiple props at the same time by selecting sub select...duh. well i did that and now i can use the trans to move the drawer in and out. i can just set the limit so it doesnt move all the way out into lala land. this works better in my case cause i have alot of doors and drawers. the doors i just move the joints to where they need to open. well thanks, im still going to play with your idea though, its something new to learn and i love to learn. bea
