Not sure I understoud what you mean??? An object created in another soft will come in the same position as it was created there if the cam inside Vue is aimed to north. But I don't know what you wanted to say by "...and then loaded the newly created objects I had added in 3dStudio to my Vue 4 model... Did you export an object from Vue, imported it in Sdstudio and re-exported/re-imported it????
I updated the model back in 3dStudio by adding new elements or objects in 3dStudio, then I want to update my Vue 4Pro project by importing those new elements and objects to my Vue 4 Pro project. In other words I'm doing all the modeling in 3dStudio and importing as I go along into Vue 4 Pro. I'm not exporting from Vue at all. What do you mean by aiming camera north, is that the main camera pointing up the screen in plan view? Thanks
I created a model in 3dStudio I then imported it into Vue4 Pro with latest update (beta)installed. Scale and size was fine after importing. Now I continued to work on my 3dStudio model and then loaded the newly created objects I had added in 3dStudio to my Vue 4 model, these new objects imported fine sizewise but were not imported on the same position as they were created in 3dStudio. Is there a way to import them so they are positioned in the same relationship as were created in 3dStudio? Thanks
